Circle2D SetData
Circle2D SetData
When I try to use the Circle2D objects SetData method from the R11 VBA environment, if I type the Circle2D object I get told I'm using a restricted method. If I do not type the variable, I'm told the SetData method fails. I'm sure this is a silly problem, anybody able to help me, please?!?
Many thanks,
Rob Lawson.
rob.lawson@airbus.com
Many thanks,
Rob Lawson.
RE: Circle2D SetData
have You created the circle already?
then You have to identify what circle is to be modified,
in VBA You have nice Insert/Object resolution tool
to get definition of the object, it uses the name of object to identify the modified element
here is sample:
Sub catmain()
'---- Begin resolution script for object : Circle.1
Dim drawingDocument1 As DrawingDocument
Set drawingDocument1 = CATIA.ActiveDocument
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
Dim drawingViews1 As DrawingViews
Set drawingViews1 = drawingSheet1.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.Item("View.1")
Dim geometricElements1 As GeometricElements
Set geometricElements1 = drawingView1.GeometricElements
Dim circle2D1 As Circle2D
Set circle2D1 = geometricElements1.Item("Circle.1")
'---- End resolution script
'example of using SetData method
Dim dX As Double
Dim dY As Double
Dim dR As Double
dX = 15#
dY = 15#
dR = 15#
circle2D1.SetData dX, dY, dR
End Sub
regards TPale
