Is the fatigue analysis required ?
I have a Div 1 vessel(1 1/4Cr-1/2Mo material) in cyclic service, with pressure and temperature flutuated at every 48 hours (600psi-100psi-600psi with 100degF-600degF-100 degF). It will have 3650 cycles for 20 years.
I try to use Div 2, AD-160.2, Condition B & Appendix 5 to see if the fatigue analysis is required. Can I substitue Sm in Condition B with the actual calculated stress intensity to get a higher allowable cycles and higher allowable range of pressure to waive the fatigue analysis ? In other words, can I increase the thickness more than required so it has lower stress intensity to avoid the fatigue analysis ?
Jeff
Jeff
RE: Is the fatigue analysis required ?
Steve Braune
Tank Industry Consultants
www.tankindustry.com
