Constrain to a plane
How do you constrain a sketch to a plane,place a dimension It just doesen't work .I have inventor6
RE: Constrain to a plane
You don't constrain a sketch on a plane you place it there. Within a part drawing select SKETCH and then select the plane you want it placed on. Unless you're doing something different that's all there is.
Cadranger
But my question was after you place the sketch on the sketch plane(i.e.XY) hoe do you constrain it to the other 2 planes(i.e XZ,YZ)
I try to use the origin planes, axis, and center point as much as possible.
You can also project part geometry from other features for locating purposes.
My problem is that I cna't constrain anything to the origin planes,axes or center point.Is there anything I should do on ,settings maybe
I try to plan ahead a little on how I am going to be putting stuff together, and often will use the YZ axis as a mid-plane and center my work around the axis.....but everyone works differently, and your technique will change as your experience level changes. I'll go back to a part I modeled 3 years ago, and ask myself "what were you doing when you made this part?"
