how do you calculate shell flow area with impingement plate
Hi all
Anyone got a formula for calculating the effective flow area through an exchanger shell when there is an impingement plate below the nozzle? TEMA 4.62 is a bit vague.
Thanks in advance
ibm
Thanks in advance
ibm
RE: how do you calculate shell flow area with impingement plate
If the latter, then the flow area is the dome area of the bundle. If the former, I can't help with a formula per se.
rmw
