Part properties
Part properties
Part properties
Hello
I'm seeking a method to handle user defined UG part attribute values with UG GRIP. Has anybody done that ?
RE: Part properties
What exactly are you looking to do? Simply edit existing attributes; add, edit, and delete attributes; or something else?
RE: Part properties
Yes. Our drawing formats are populated and edited from a GRIP program and attributes.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Part properties
I'm trying to read values of those user defined partfile attributes and then write them out to text file.
RE: Part properties
Here is some code snipets:
Reading an attribute to a variable:
attvar = &attvl(part,'attribute_name',iferr,l00:)
Replace attribute_name with your attribute. You can use an array in a loop.
Create a text file:
create/txt,10,'text_file_name.txt',iferr,err0:
Writing a line of data to a text file:
Format mask
fmt1='#@@@@@@@@  #@@@@@@@@@@@@@@@@@ #@@@@@@@@@@@@'
write/10,using,fmt1,attr1, attr2, attr3
file/txt,10
Ben Loosli
Ingersoll-Rand
RE: Part properties
Hi guys
I am lokking for function to get UG part attrubutes using VB6. I tried to make C/C++ program to get attr. using API but I failed on that. I don know how tyo do that.
Can you help me pls?
Tnx
RE: Part properties
UG does not support VB up through NX2. NX3 may change that.
Your only methods for getting atributes out of UG are GRIP or C/C++.
Ben Loosli
Ingersoll-Rand
RE: Part properties
Thnx man
but I unfortunately I do have problem with C/C++ API functions. Code runs through UF_ATTR_ask_part_attrs_in_file function but all parameter are empty. So I dont know how to write correct code pls help me
Tnx Miro V
RE: Part properties
Sorry, I don't write C code.
Ben Loosli
Ingersoll-Rand
