Spark Gaps Manufacturer
Can someone help me find manufacturer of Spark Gaps.
I'll appreicate any help.
thanks
RE: Spark Gaps Manufacturer
Dear Sordonyx
Did you search with google? I found a lot of manufacturer.
Do you looking for special product?
Kerem SENCAN
Component Engineer
www.designchainassociates.com
Thanks Sreid! Keremsencan, yes I did search in google and sorry I didn't specify my question. I need a surface mount (if possible) or the smaller the better, low voltage. I found Sankosha and Bourns too. Are there any manufacturers?
Try searching Electronic Engineering Master
www.eem.com
Any chance that you could use a Transcient Voltage Suppressor (TVS) in place of the spark gap?  I believe that TVS are available in surface mount.
Thanks to both of you, I'll try to ask our design engineer if he could use TVS. I'll look for EPCOS and Littlefuse too.
