Iterating a body copy/move with a macro
Hi Everyone...I am trying to set up up a macro that will rotate a body around the X-Axis (as a copy) and then rotate the copied body around the Z-axis, in equal increments for a given amount of iterations. Below is the code for the loop.
For I = 1 To 10
boolstatus = Part.Extension.SelectByID
("Extrude1", "SOLIDBODY", 0, 0, 0, False, 1, Nothing)
Part.FeatureManager.InsertMoveCopyBody2 0, 0, 0, 0, 0,
0, 0, -0.03490658503989 * I, 0, 0, True, 1
("Body-Move/Copy<2*I-1>", "SOLIDBODY", 0, 0,
0,False, 1, Nothing)
0,0, 0, 0, 0, 0.03490658503989 * I, False, 1
Next I
In the highlighted line I am trying to select the body that was just rotated around the X-axis to be rotated around the Z-axis (the pattern will be 1,3,5,...), but VB does not calculate 2*I-1 inside the quotations. Is there a way I can get the program to select Body-Move/Copy(2*I - 1)?
For I = 1 To 10
Next I
