Reduce Model Size
Reduce Model Size
Reduce Model Size
Is there a way to "clean up" a model in Solidworks 2004 to reduce file size? I've been working of a couple of plastic models that were bought in as STEPped imported bodies and have grown to 40-50 meg files (they started as 6-10 meg). Seems to me that there must be a bunch of junk that I should be able to get rid of. Being a former UG operator, I don't know how to do it in Solidworks.
Thanks - Dave
RE: Reduce Model Size
Use the Search Tab - This has been discussed to death.
Thread559-97903
Thread559-99954
Thread559-87991
Thread559-67844
Also run a search at www.google.com under the comp.cad.solidworks forum.
If the model is not solid they tend to be larger, until you get them to a solid.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
