aluminium extrusion snap design
Can somebody give me some directions in finding a good design-guide for Snap-fit design in aluminum extruded parts ?
TIA.
RE: aluminium extrusion snap design
Take a look at plastic snap-fit design guidelines.  You can probably find it easily enough if you do a search on the internet.  The only thing that is really different are the material properties between aluminum and plastic.
- - -Dennyd, P.E.
Aluminum Association has a design manual which can be purchased from their website. I use it every day and answers all of your aluminum design questions. I found by using this, the mills give fast turn-around to die designs when you spec as per the design manual.
www.aluminumassociation.org (If I remember correctly)
www.aluminum.org
Sorry, I got the website mixed up and I can't find an edit button anywhere...
RikuY
