Tolerance Stack-Up Analysis
Does anyone have an Excel Spread Sheet that is setup to give you feedback with Tolerance Stack-up?
Thanks!
-Art
RE: Tolerance Stack-Up Analysis
Just make a simple 3 column sheet ,,, nominal, plus & minus.
Enter the drawing data making sure that you interpret the tolerances correctly so the stack is directional.
Sum the + & - columns and you have your range
Keep the wheels on the ground
Bob
showshine@aol.com
