Exporting assemly from IDEAS to PROE
I need to export an assembly from IDEAS to Pro/E. I do not spend my time exporting each part seperatly and assmebling them into Pro/E. Is there any way to export it to Pro/E as an assembly with all different part in it?
RE: Exporting assemly from IDEAS to PROE
My problem is that ideas creates the step file for each different part. I mean I do not have one step file containig all the assembly parts. Is it the way how it works? or am I missing somethig?
Thank you,
Regards.
umit
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Irwin
The STEP translation should also work, and from my experience with better results to Pro-E. Not sure why you're getting individual STEP files for each part.
With the Assembly on the Workbench Select:
File -> Export -> STEP
Double click one of the instances so that the entire assembly is selected, Select return, and leave the default STEP 214 option selected and press OK. For me this gives a single STEP file containing the Assembly Hierachy.
If you don't get this, what version of I-DEAS are you running?
