VAST DIFERENCE IN DIGIATL VS ANALOG METERS
I have had vast difference in reading on insulation- resistance for MI Cable, the digital meter [by YOKOGAWA -24060 MEAS] shows about 6.0 Meg Ohms and an analog [MEGGER by BIDDLE] meter shows about 7 Gigs for the MI cable. The reading with both meter were taken more than twice and appears to give readings. Can anyone explain why such a vast difference for the same feeder? The full-scale setting for analog meter was correct.
EEAOC
EEAOC
RE: VAST DIFERENCE IN DIGIATL VS ANALOG METERS
Compare the two meters reading 1 megohm, then a string totaling ~100 megohms of 5% fixed resistors.
Might the Guard terminal been used on one meter and not the other?
