Temperature Drop across pipe
All,
We have a gas at 280F. This gas is sent to Amine unit for further polishing.If the amine unit is approx 2 miles downstream would there be any temperature drop
Any help will be appreciated
sp
sp
RE: Temperature Drop across pipe
My hot water heater is only 40 ft from my shower and there's a temperature drop.
TTFN
Insulation.
Velocity
Gas Properties
Ambient conditions
To name a few.
By the way, older homes are built with copper water piping, which is a pretty good conductor, so don't expect as dramatic a drop as from your hot water tank to your shower.
Thanks for your assistance,
Is there a theorotical method by which I could be able to calculate the temperature drop across the length of the pipe.
Any suggestions welcome
sp77
>> h heat transfer coefficient
>> A area
That said, your piping insulation, fluid flow rate, solar load and ambient air also need to be factored in. Overall, there's no simple closed-form solution, but there are thermal analysis programs that could probably do the numerical analysis.
You can potentially set up a lumped parameter model of the pipe and at least get a reasonable swag.
TTFN
Take a look at
http://www.cheresources.com/insulationzz.shtml#
There's a link to a spreadsheet at the bottom that will help with your question.
Larry
If the pipe is relatively well insulated, then the process follows that of a Fanno line.
You might wanna look on www.tycothermal.com (a.o. supplier of Raychem heat tracing) as well.
regards
Your questions are very "basic". How will you document and QA any calculation based on what you can read here?
Best regards
Morten
