Huge Dwg size with no entities
I have a dwg that is 2 mb in size and should really only be about .5 mb. It was sent to me from a client. I purged completed, tried to wblock it, ran a qtext check and it is still 2 mb. I then did a little test: opened up a new empty dwg and saved-it was 25kb. Then copyclipped one line (yes only a line about 4' long, nothing special) from the large dwg into the new dwg and saved. The new dwg saved at 1.5 mb. The same thiung happened no matter what I copied into the new dwg, it always seemed to bring other 'hidden' invisible things over. There is nothing in the dwg but a line. I then tried to purge this new dwg again, said nothing there, but still saved at 1.5mb. When I did an audit pass #3 said there were 20,000 items, but what and where? Then tried to recover it, this also listed 20,000 items. No idea what they can be. There is nothing that I can think of to do. It is incredibly frustrating trying to saved what should be a small dwg and it takes 2 minutes. Not to mention trying to just edit it. Any ideas?
RE: Huge Dwg size with no entities
this should help.
http://www.caddevelopmentgroup.com/Downloads.htm
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
I think the drawing is not made by Acad. Did You save as r12.dxf?
Lothar
ADT 2004
ACAD 2002
http://www.eng-tips.com/viewthread.cfm?SQID=94374&SPID=555&newpid=555&page=1
"Everybody is ignorant, only on different subjects." — Will Rogers
Are there any objects in any of the layout tabs?
It could be any number of things, but it seems impossible that there is nothing in the drawing. I have ADT drawings that are full of 3D objects, and I rarely get over 1MB
The foundation plan I am working on right now is only 267K, and it is all in 3D.
Try saving it down to R12 to see if it will purge everything out.
(defun C:LayerFiltersDelete ()
(vl-Load-Com)
(vl-Catch-All-Apply
'(lambda ()
(vla-Remove (vla-GetExtensionDictionary
(vla-Get-Layers
(vla-Get-ActiveDocument
(vlax-Get-Acad-Object))))
"ACAD_LAYERFILTERS")))
(princ "\nAll layer filters have been deleted.")
(princ))
(defun C:LFD () (C:LayerFiltersDelete))
John Peterson
www.wba-arch.com
Your lisp routine was the ticket.
The layers filters were the cause, all 20,000 of them. (Yes 20,000) Apparently layer filters follow a copyclipped entity to the new dwg. I guess that's how there became so many. I never would have found them.
Here's the breakdown: Drawing started at 1.4 Mb, after running your routine, new dwg size... 57 kb.
Many Many Thanks
Kevin
