2D assembly lines
2D assembly lines
2D assembly lines
Does anyone know how to hide the assembly lines that show up on a 2D drawing?  It would make the 3D view on the 2D drawing look better.  On cables I can usually do a break and get rid of it, but not on the 3D views.
RE: 2D assembly lines
If you're using Pro/E 2001 View/disp mode/edge disp/ then pick the view(s) then pick your line visibility.
Thanks for the reply.
I am using Wildfire 1.0.  I don't get the same options as what you described.
Try the menu mapper.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
