Tapped Hole Modeling
Is there some where you can download nuts with the actual tapped section intact. I can easily find the screws and bolts but not the nuts. I am creating a mold and need have the tapped section modeled.
-R
-R
RE: Tapped Hole Modeling
OR
Just draw a basic nut and call out the correct info on the drawing? I'm sure the model of the thread doesn't matter, as long as the BOM calls out the right part. (unless you are using finite modelling to test a thread)
Good Luck!
Modeling the actual threads requires a spiral cut and that gobbles up wa-a-a-ayy too much disk space. I think you'll have a tough time finding what you seek.
TygerDawg
