3D Text around an circumferance?
Hi guys,
I've been asked by our R&D team if I can show 3D text in the model such that it shows up when I produce renderings for them. I know that this can be done - my problem is that the text needs to go onto the end of a cylinder and then follow around the circumferance - if you know what I mean (similar to the techniques used in Wordart on MS Word).
Cheers,
Lee
Cheers,
Lee
RE: 3D Text around an circumferance?
Steve
http://www.sprdesign.com
Any chance you can elaborate a little - I'm still novice with Pro/E - using 2001i at the mo.....I've sketched a datum curve onto my disc......how do I get to the TEXT command!!
Lee
If I understand you correctly, for 2001, select FEATURE --> CREATE --> SOLID --> PROTRUSION --> EXTRUDE. Select the planes sketch view etc. The from the Main Menu at the top, select SKETCH, TEXT, define a vertical line, for the height, type in your text, and check the PLACE ALONG A CURVE, you may nned to flip the text as it seems to have a habit of inverting itself.
Is this what you require?
Hope this helps.
maybe only a drafter
but the best user at this company!
I go:
FEATURE-->CREATE-->SOLID-->PROTRUSION-->EXTRUDE
Select my sketch plane & Default plane as TOP
Select default planes as Refs
Then go SKETCH-->ADV GEOMETRY-->TEXT
Enter text as required - then I'm prompted for box to place text - draw a box on the screen and text appears. But no option for "PLACE ALONG CURVE". Is this on later release only perhaps??
Lee
Cheers for input guys - I'll have to wait until we go live with 2001 in a couple of weeks......
Lee
What you can do with 2000i is create each text letter seperately and align it as you require by making the proper
sketching refernces. This can simulate a circle.
Steve
Thanks Guys
Do you mean around the cylinder, or up and down?
Hope this helps.
In Wildfire 2,
Create a datum plane a known distance from the cylinder, create one letter of the text, select, EDIT --> FEATURE OPERATIONS --> COPY and do a rotate, this may need tinkering to get the correct angles.
I may be able to send you a file if you wish.
Then do a cut along the cylinder to get the text to the correct height.
Is this any use?
Hope this helps.
