I am hitting a road block here and
I am hitting a road block here and am hoping that this is the correct forum for this question.  If anyone thinks there is a better forum for this question, please let me know.
I am having a problem with a vacuum system on the press section of a paper machine.  To make sure my piping is not the problem, I have been trying to calculate a pressure drop on my vacuum piping.  I have looked at freecalc and efunda.  They both have scripts to calculate friction loss of duct, but neither addresses any change in the viscosity of air in the vacuum system.
I would guess that hot (180 degrees) saturated air has a different viscosity than standard air and all calculators use the viscosity of standard air.  I think I can make the final calculation myself, but I don't like using numbers that I don't think are correct.  Now if the difference in viscosities between saturated hot air and standard air results in less than 5% in the final answer, this should be stated.
I am breaking out the thermo book, fluids book and Crane 410 tonight, but all of the formulas result from there and do not address these concerns.
Am I worrying too much?
Looking for some confidence in the numbers.
RE: I am hitting a road block here and
I've got an older version (2.1) of the ABZ program (based on Crane 410), and if I punch in atmospheric pressure air (0 PSIG) at 70*F, it says the absolute viscosity is 0.018 centipoise, and the kin vis is 14.953. At 180*F, these change to 0.02 and 20.882 repectively.
Being an older version, it doesn't have any fancy graphics, but I don't care. I LOVE that program. One of the best $150 I ever spent.
Here the output from a simulator that saturates the air.  Notice that the air is 53% water at the temperature and pressure (14 psig and 180 F).
K-VALUES: ASOA     ENTHALPY: ASOA     DENSITY: STD    FLOW RATES /HR
  VAP VISC: NS81     VAP THC:  NS81
                      TOTAL   LIQUID    VAPOR    TOTAL    TOTAL
 COMPONENT NAME       LBMOL    LBMOL    LBMOL     LB    MOL PCT   KVALUE
AIR                  26.3555       0.  26.3555  763.361   46.120
WATER                30.7898       0.  30.7898  554.689   53.880
TOTAL                57.1453       0.  57.1453  1318.05  100.000
TOTAL   LB           1318.05       0.  1318.05
STREAM NUMBER    1
TEMPERATURE DEG F      180.00
PRESSURE    PSIA       14.000
ENTHALPY    BTU/HR     62859.
VAPOR FRACTION         1.0000
PROPERTIES              TOTAL       VAPOR
FLOWRATE   LBMOL/HR      57.1453     57.1453
MOLECULAR WT.            23.0649     23.0649
ENTHALPY BTU/LBMOLE    1099.9913   1099.9912
ENTROPY  BTU/LBMO/R       3.4325      3.4325
CP       BTU/LBMOL/R                  7.5872
CV       BTU/LBMOL/R                  5.5764
CP/CV                                 1.3606
DENSITY  LB/FT3                     0.047185
Z-FACTOR                            0.997059
FLOWRATE FT3/SEC T-P                  7.7594
         MMSCFD  STP                0.520380
VISCOSITY   CP                      0.012973
TH.COND  BTU/FT/HR/F                0.019687
Don't forget that the delta-p should be less than 10% of the absolute pressure or the pipes will choke.  Do you have welded or screwed joints?  Threads leak (by definition)
