need more info on exploding assy's
OK so I got the basic yet primative advice on exploding (which was great... thanks to everybody who helped with the info) but I need some more advice.
OK here goes, I have many parts within this assy that are concentric to each other with within the assy. Now as I explode parts through various "explode steps" I can't seem to get the concentric parts to align "concentrically"
In other programs you can explode a part and then explode other concentric parts (and edges for that matter) and they would explode properly. So lets say I have a cube with a hole in it and it is exploded along the Y and X axis so now it is in a location/plane/axis different from where it was originally. now I want to explode a dowell pin which fit inside the cube with the hole. now with another program I had you could pick the cube as the part you wanted to base your explosion from then choose the hole as a concentric relation and then choose the dowell pin and the part would explode the pre-defined distance and be aligned concentrically with the hole in the cube even if the cube was on a different axis and location.... now I have played around with solidworks trying to figure this out but have had no luck. Any advice???
RE: need more info on exploding assy's
