Faster Excel Macro
Faster Excel Macro
Faster Excel Macro
How can I speed up this section of my macro?  I have enough data that this one part takes 45 min.  endRow ~ 18,000.  It just copies the part number into column A.  Original data looks something like this:
Drawing   12345
          abc
          def
23456     23456
          abc
junk
34567     34567
          abc
Drawing   45678
    For k = 2 To endRow
        Cells(k, 1).Activate
        curCell = ActiveCell.Value
        firstCh = Left(curCell, 1)
        If ActiveCell.Value = "Drawing" Then
            pn = ActiveCell.Offset(0, 1).Value
        ElseIf firstCh = "1" Or _
                firstCh = "2" Or _
                firstCh = "3" Or _
                firstCh = "4" Or _
                firstCh = "5" Or _
                firstCh = "6" Or _
                firstCh = "7" Or _
                firstCh = "8" Or _
                firstCh = "9" Or _
                firstCh = "M" Then
            pn = ActiveCell.Value
        End If
        ActiveCell.Value = pn
    Next k
When finished it looks like this:
12345     12345
12345     abc
12345     def
23456     23456
23456     abc
23456
34567     34567
34567     abc
45678     45678
RE: Faster Excel Macro
No idea if this makes a difference, let me know, there is probably an even better/quicker way.
Application.ScreenUpdating = False
 For k = 2 To Range("A65536").End(xlUp).Row
        'Cells(k, 1).Activate
        'curCell = Cells(k, 1).Value
        firstCh = Left(Cells(k, 1), 1)
        If Cells(k, 1).Value = "Drawing" Then
            pn = Cells(k, 1).Offset(0, 1).Value
                firstCh = "2" Or _
                firstCh = "3" Or _
                firstCh = "4" Or _
                firstCh = "5" Or _
                firstCh = "6" Or _
                firstCh = "7" Or _
                firstCh = "8" Or _
                firstCh = "9" Or _
                firstCh = "M" Then
            pn = Cells(k, 1).Value
        End If
        Cells(k, 1).Value = pn
    Next k
Application.ScreenUpdating = True
Hope this helps.
maybe only a drafter
but the best user at this company!
Have come up with an alternative version, does this spped it up and is it still working as expected?
        If IsEmpty(Cells(k, 1).Value) Then GoTo CONT
        Range("G1").Value = Asc(Left(Cells(k, 1), 1))
        Else
            If Asc(Left(Cells(k, 1), 1)) >= 48 And Asc(Left(Cells(k, 1), 1)) <= 57 Or _
                Asc(Left(Cells(k, 1), 1)) = 77 Then pn = Cells(k, 1).Value
        End If
CONT:
    Next k
Hope this helps.
I had already taken care of the Screen Updating.  I'm sure my problem is with the If checks, especially the 2nd.  I'll see what I can do with what you proposed.  One of my problems is not every cell in all 20 columns has something in it and it's not consistent either.  That's what I'm trying to fix, i.e. to group everything by part number.
Your version took 10 min longer.  It certainly looked faster anyway and I picked up some great techniques so your effort certainly wasn't wasted.
Most of the time I have to slightly modify code that gets written here.  Your's worked perfectly.  I must have done a better job describing what I needed than usual.
I found that 1/3 of the rows processed are completely blank.  I'll have someone go in and delete them.  That should cut down on the time considerably.
Roger
If you have a large list of data where you wish to group by certain cell value you should look at a pivot table.
If you are familiar with this feature of excel i wont bother you if not please post back and i will broaden.
Best regards
Morten
Just a couple of general suggestions.
1. Rather than re-evaluate the last row every time through the loop, do it once before the loop.
2. Only evaluate firstchr if you need to (test for "Drawing" first)
3. Use Select Case rather than multiple ElseIf...Or
4. To help optimise add a timer so you can see what's going on.
I've incorporated these suggestions here:
x = Timer
l = Range("A65536").End(xlUp).Row
 For k = 2 To l
        Else
           firstch = Left(Cells(k, 1), 1)
        Select Case firstch
        Case 1 - 9, "M"
                    End Select
        End If
    Next k
y = Timer - x
MsgBox "Test took " & y & " secs"
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Morten,
A pivot table is indeed just where I'm headed.  Can I make a pivot table pull data from 8 separate files with 20+ worksheets each?  If I can then I don't need this macro.  I guess I assumed that all the data had to be on one worksheet.  Obviously I've done very little with pivot tables.
Even then would a pivot table be able to associate line def with drawing 12345 in my example?
John,
I did use a time check but not Timer as you did.  Much more elegant, thanks.  I'll give this a try.
Roger
John,
I get a type mismatch error for the statement:
Case 1 - 9, "M"
I'm running Excel 97.  I tried Case 1 To 9, "M" and it errored also.
wel in office 2000 you can make multiple ranges (havent used it myself so im not familiar with details).
This function can be called from VB - so that initially you can use the workbooks and sheets collections to find all sheets and the insert that into the funtion call (providing that each page has the same input field.
Best regards
Morten
It works fine in Excel XP. Unfortunately I don't have a copy of 97 to test on. You could try replacing:
Case 1 - 9, "M"
with
Case "1" - "9", "M"
You can also trim the odd microsecond by replacing:
with
pn = Cells(k, 2).Value
Good Luck
johnwm
Hi Roger,
I decided to give a hard look at this. I repeated your data  in 20000 +rows in one worksheet, it takes about 2 seconds to organise with code given below. Have I overlooked anything?
I am using excel 2000 .
 For k = 2 To l
        If Cells(k, 1).Offset(0, 1).Value = "" Then GoTo End1
        ' can use currentCell.EntireRow.Delete instead of GoTo End1
        Else
        'Select Case firstch
        'Case 1 To 9, "M"
 ' use following two if if Case does not work
            If Val(firstch) >= 1 And Val(firstch) <= 9 Then pn = Cells(k, 1).Value
            If firstch = "M" Then pn = Cells(k, 1).Value
                    'End Select
        End If
End1:
    Next k
y = Timer - x ' thanks john
MsgBox "Test took " & y & " secs "
You can also get rid of blank rows by serialising & sorting data before running any macro.
Use pivot tables after this organising . Look for help with 'consolidate multiple data ranges' to use data from many sheets.
best regards,
GK
