Sprayball Testing
Sprayball Testing
can some one tell me what exactly is Sprayball Testing and why and where it is used? I came across it while browsing
http://www.psitanks.com/spraybal.htm
RE: Sprayball Testing
The Balls are fitted into tanks that normally contain product being either mixed or stored, periodically these tanks need cleaning, usually with some form of acid followed by clean water.
Because the cleaning operation is done on an automatic cycle and is normally not visually checked or verified, it is imperitive that the spray from the ball reaches all of the internal surfaces of the tank. (Not so simple as you may believe).
Testing or calibrating the ball to the vessel is to ensure complete coverage of the vessels internal surfaces.
