Drawing View and Section Orientations Flip 180 degrees
I created a multi-sheet drawing view of a 2 part assembly.  Everything looked great until I exited PRO/E went to interlink, and opened PRO/E again.  Now two of my primary views are rotated 180 degrees (or flipped?), and two of my section views flipped as well!
The section views are now no longer correctly shown with respect to the section line orientations in the main views.
Any ideas what happened and how to fix it?
To start the drawing sheet, I did not use the default 3 views, but placed one view and then did two projected views from it.
Any help greatly appreciated!
RE: Drawing View and Section Orientations Flip 180 degrees
mm137,
Beacuse you work out of intralink. All last changes and saves you've done are not seen by intralink. Move your files drawing and parts/assemblies into another folder. Then go back in intralink and import them. This should fix your problems.
-Hora
