Good Place to Go for Info on AutoCAD R14
I am trying to set up preferences for a little used AutoCAD program I use.
Is there a good web site to go to for help?
RE: Good Place to Go for Info on AutoCAD R14
Instead of hunting down websites and software, ACAD environment setting can be saved as a user profile. A profile is a set of custom preferences in case of multiple users are using the same workstation. Go to TOOLS>OPTIONS and pick the Profiles tab. You can create your own profile by picking the Add to List button. This opens the Add Profile dialog box which is used to name and create a description for a new profile. The current setting are save to the profile. Additionally, various profiles may also be useful to a single user with different preferences for different projects. Hope this helps - John
