Blocks in xrefs
Blocks in xrefs
My problem is that im designing a storm water system for a commercial development, and i created a new drawing and xref'ed the the entire site into the new drawing. Now everything is appearing in model space. But when i tile over to paperspace in my viewport everything is showing up again except for the actual drain inlets. I went back to the original drawing where the xref came from, and it turns out that the drain inlet was a block. why isn't the drain inlet block showing up in the new drawing?
Do i have to explode the drain inlet blocks and save?
help please!
help please!
RE: Blocks in xrefs
