Brackets around a dimension
Hello all,
I have a set of brackets around a dimension. Is there a way to control the spacing between the brackets and the dimension value?
Thank you!
RE: Brackets around a dimension
dear silverunner,
You can use the offset constraint. Modifyng the offset value directly from its dimension will change the distance.
Farzad
