Generating a helix that follows a defined radius
I would like a generate a helix that follows a defined radius.  This helix will be used to generate a compression spring using a sweep.  I would like an equation that I could modify based on input variables (pitch, length, radius, angle of radius, etc) that would give me (x,y,z) points that I can import into solidworks via excel and generate a composite curve.  It seems someone has needed this before, and I do not want a swept tube, I have already done that before.  In the future, I think the deform/warp feature on Solidworks 2005 will modify my existing helix.
RE: Generating a helix that follows a defined radius
SWX 2005 now has a 'twist' option for sweeps.  Using this, you can specify a number of rotations that the sweep profile will go through while being swept along any path.
This can thus be used to create a FULLY PARAMETRIC helical curve along any path, curved or straight.
Check it out!  I bet you will be pleased.
Arlin,
Thanks.  I cannot wait until SW2005 ships.  Maybe I will not need a PHD in math to generate this helix after all!
2005 PR1 is available for download by all subscription customers now, if you want to check it out.
I suggest downloading on seperate pc from 2004. Could have conflics if together.
I run SW03, SW04, and SW05 PR1 all on the same PC. You just need to rename the directory to in which you install SW into.
For SW03 I use Solidworks03
For SW04 I use Solidworks04
For SW05 PR1 I use Solidworks05 PR1
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
