math packages for ee calculations in autocad EE software
I was wondering if there is a math package for EE calculations in the autocad software programs? Or if there is a corresponding package that you have to buy seperate? Thanks--Lanny
RE: math packages for ee calculations in autocad EE software
http://www.adeptscience.co.uk/products/mathsim/mathcad/
"Everybody is ignorant, only on different subjects." — Will Rogers
Mathcad: general "blank sheet" math program with units built into the calculation process and on-the-fly unit conversions.
Matlab: good at matrix math and the standard tool for discrete time/event simulation of mathematically based systems, e.g., servos, etc.
Mathematica: high-end symbolic math program
Maple: ditto
TKSolver: table-based math program comparable to Mathcad
etc., etc.
TTFN
You can use AutoCAD's built-in customization
programs to create the calculation routines
you need. Have used this method to do pressure
vessels calculations (sheel/head thicknesses)
and then automatically draws the top, elevation
and section view of the pressure vessel.
Never used it, so no more information than the above.
TTFN
