MOTOR TERMINAL BOX
MOTOR TERMINAL BOX
Is there a latest standard for Motor terminal box/ volume/ amps? Looking for industry standard? Nema? NEC? Thanks in advance for your help.
RE: MOTOR TERMINAL BOX
As far as I know there is no industry standard for terminal boxes....but they are governed by the IP rating of the motor...ie. protection against ingress of dirt,water etc. and also hazardous area use motors, such as flameproof motors etc.
hope this helps
Jeff
www.motors-direct.co.uk
In ANSI regions, reference 1999 NEC §430-12 Motor Terminal Housings
or IEEE Std 841-2001 §6.5 Main terminal boxes and terminal leads
or NEMA Std MG 1-2003 §4.4 …Dimensions
