Broken view cutting line
Greetings,
When creating a broken view of a cylindrical component (eg. long rod), by default the cutting line is a "zig-zag" style.  Is there a way to change this default standard (eg. 3D "S" type)???
Thanks!
Peter
RE: Broken view cutting line
I didn't see an 'S' shape option from the drop down list.
How 'bout as a work around delete the heart beat and sketch the S using a spline then use translate to create the other instance.
