Lots of Blocks, One Big Problem
Hi folks
I have a major issue that I don't seem to be able to crack. CAN U HELP?
I have recently received some converted CAD data (from Microstation to ACAD) that has a number of blocks that are identical in every way, with one exception. Each of the blocks has been assigned its individual name.
For Example a sink might have the block name "673452-6763-Sink-00062a" and a similar block will be named "673453-6763-Sink-00262c" I can filter out the relevant blocks using the common value 6763-Sink which I can then Copy and paste into the required drawing.
My question is this. Is there a method of being able to redefine these blocks to one common block name (Say "Armitage_Sinks_Type_264353") ?
Any and all help/advice will be greatly appreciated
RE: Lots of Blocks, One Big Problem
"Everybody is ignorant, only on different subjects." — Will Rogers
As an alternate suggestion, you would have to exit windows and enter DOS. At the prompt, the REN or RENAME command renames a file or a group of files. The command structure is:
REN [drive][path] filename1 filename2
Tip: Use wildcard symbols ? and * to globially select the files you want to rename. Hope this helps - John
