Notched stair stringer
I am checking the stringer capacity for an existing stair. The stringer is a Trus Joist 1.3E LSL 2x12 (1 1/2"x11 1/4"). The stringer has been notched for steps (7 3/4" rise, 10" run). There are 12 steps which makes the total run 120" and the total rise 93". The pair of stringer are 36" apart. I am using 10psf dead load and the required 40psf live load. This stringer does not work. Is there something that I am missing?
RE: Notched stair stringer
With wood contruction I use stinger spacing of 18" or 24" OC (reduces the tread deflection and stringer stress). Loading I use for stair systems is 100 psf. Dont forget about the hand rail loads and resisting its rotation. Consider nailing and gluing the treads and risers.
Is part of the stringer cut flat on the bottom? Maybe you can pick up a few inches here and there to reduce the actual clear span to make it work for moment (assuming that is what is governing)
You said a Truss Joist which is an "I" member with two flanges and a web. When you notched the member you destroyed the flange and ruined the member. The standard stringer is a 2x12 at 18" o/c for a 36" stair.
My quick check indicates that the net effective member (1 1/2" x 5 1/8") spanning 10 feet fails in both bending and deflection using 100 psf. At 40 psf bending works, but it's a little bouncy. I think most codes allowthe use 40 psf for residential stairs that serve one dwelling, but I prefer 100 psf. 100 psf is required for egress stairs on multi-family residences.
Make sure they didn't over-cut the stair notches!
The inside face of the stringer is accessible as is the bottom edge.
Add 2x4 (or 2x6) to the inside face of stringer.
Add 4x4 posts ((2)-2x4's) at two locations at the underside of stringer.
