Laser Cutting Quoting Software
Does anyone know of a good stand alone Laser Cutting Quoting Software system.
Steve
RE: Laser Cutting Quoting Software
Most CAD/CAM software can do simple profile calcs, some will also derive a time based on autotooling the profile. I'd check your CAM system first it may do all of what you need.
In the past I've tended to use simple spreadsheet/worksheets for laser quoting in the past, I'm in the process of writing a utility to calculate profiles lengths and number of pierces from a DXF file and intend to try and combine the two (using openoffice.org not MS office).
from dxf or it's own flexi shape library, calculating cut/
pierce time with assit gases as a unit cost per minute or metre.
The only other software we have found is Instant Quote
from LMC Laser this software imports a dxf prenested
and then caculates costs inc gas usage very accurately. not quite as good but only costs $400 approx.
Does anyone know of any alternatives ?
steve
