Referencing entities within a drawing.
Not so much a problem, but a curiousity. I'm sure that there must be a way of doing this, but I can't find anything in the help.
When I'm doing a jig and tool layout sheet, it consists of a drawing of the finished jig, or tool, assembly, and on the same sheet is a drawing of each individual component that makes up the assembly. So if I was designing a screwdriver, there would be a drawing of a complete screw driver at the top, and underneath that would be a drawing of the handle, and underneath that would be a drawing of the blade.
Now, is there a way, WITHOUT using XREFS, of working in the drawing so that any modifications to the handle (say), would also affect the handle on the assembly drawing?
So in other words, if I added a chamfer to the handle on the component drawing, a chamfer would automatically appear in the same place on the handle in the assembly drawing?
XREFs are no good, though I know they'd work. Believe me, from bitter experience...other people work on these drawings too, some of whom are still getting to grips with the concept of drawing on computers. Trying to explain xrefs to people who prefer drawing boards is just far too complicated...
So I suppose what I want to do, is use an xref without the X part..!
Anyone?
Anyone?
RE: Referencing entities within a drawing.
The reason I did not try it is the feeling that I would have to attach extended data to re-identify lines and circles, which would be cumbersome.
Has anyone tried this? Any good?
Layer names
handle
blade
handle dims
blade dims
assembly dims
For the handle, turn on layers 'handle' and 'handle dims' and all others off.
For the blade, turn on layers 'blade' and blade dims' and all others off.
For the assembly, turn on layers 'handle', 'blade' and 'assembly dims', and all others off.
Am I making any sense?
I'd be interested to learn if you find out a method to achieve the same result in AutoCAD. design@waterplay.com
Your drawing will need to be created with the EED added to each entity to enable the selection of individual entities that require alteration.
An example of this would be adding a door to a plan with an and automatic update in the elevation.
Not impossible just difficult.
