Suggestions to finding a small capacity electric water boiler
Can anyone suggest a company or place to find where I could order a small capacity water boiler. I am working on a research project and I need a boiler that is pressure controlled that can produce steam with a range from 0-150 psi gauge. With a maximum capacity of 2 gallons.
RE: Suggestions to finding a small capacity electric water boiler
Hope this helps.
saxon
you mention.
These people make small steam generators. I would call them and see what they have.
http://www.silvereaglemanufacturing.com
Here is the laboratory type steam generator.
http://www.coleparmer.com/catalog/product_list.asp?cls=5554&par=0,5552&cat=1&sch=508&sku=&sel=
Search this site; www.graham-mfg.com
rmw
a 100 psi trim, 85 psi operation is a lot cheaper say $ 2,000.00, a 150 psi trim 135 psi operation about 2,500
go to www.generalboiler.com
ER
