question RE: exploded views
OK once again I have come upon a stumbling block, and I was doing soo well too.
my question is regarding general info in seperate exploding steps for exploded views. so I have figured out how to create a "NEW" exploded step... click on the part to explode then a face for the direction , then click accept.... bur I have have yet figure out how to move the part. the part; once exploded goes in a general outward position perpendicular to the face you chose but what if I want to move the part up or down since my assembly has a ton of parts to it some pieces overlap each other. also I am trying to add explode lines is there an easy way to edit the lines?
thanks in advance for the help
RE: question RE: exploded views
As for editing explode lines, I have found it much easier to just delete the existing lines and reinsert them. This may not work for you, but I found it easier.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
