A large hole in the web of an important shear wall
I have a large shearwall subjected to large moment and shears and I have detailed as follows
1) End zones take the moment
2) web takes the shear by longitudinal and horizontal reinforcements uniformly spaced.
Now the architect wants a large hole in the web close to foundation level. So I am losing my shear transfer.
I am thinking of transforming into a heavily reinforced beam just above the hole to act as a compression member and then spread out the compression force to foundation by using a pair of diagonals again using heavy reinforcement.
V---> 1 -------------------------1
1 * * 1
1 * * 1
1 * * 1
1 * * 1
V=shear force
1=end zone
--- = my new compression member hidden in the wall
*** = my new diagonals hidden in the wall
I will anchor diagonals into beam and end-zones carefully and tie closely
Do you think this one will work.
regards
IJR
1 * * 1
1 * * 1
1 * * 1
1 * * 1
V=shear force
1=end zone
regards
IJR
RE: A large hole in the web of an important shear wall
The detail above will be used at basement level where I expect very small drifts. So I guess I am not going to have drift induced moments. I will check on it anyway
Additional thanx Ron
respects
IJr
