Tolerances in Hole Callouts
Hi. It is possible to add a tolerance in a counterbore or countersink hole callout? I need to make a counterbore hole, but with tolerances, and I don't know if this is even possible.
THank You
Adi
THank You
Adi
RE: Tolerances in Hole Callouts
Bradley
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
