Is there a way to show the pull down under data validation?
I am using a data validation "list" and would like to set the pull down to be always shown. Currently it only shows up if you have the cell active. I would prefer not to use the forms/column box so the information can be copy and pasted later.
Any Ideas?
BsurfN99
Any Ideas?
BsurfN99
RE: Is there a way to show the pull down under data validation?
brainstorming thought...
perhaps you can create a small bitmap and embed into cell and set to background. you will need to be certain that the actual pull-down for data validation is available. sort of creating a false representation, but just a thought.
god luck!
-pmover
good luck!
-pmover
