Turning off background images
I have a couple parts and assemblys with background images, but the Insert/Picture function is greyed out. I'm not sure if there is an easy way of removing the image? Is it possible the parts where encoded to prevent removing of the image?
Thanks for any suggestions.
Matthew.
Matthew.
RE: Turning off background images
View\Display\Picture - Uncheck it
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
