Switching between 200V and Low Voltage Sensor
Hi all, I'm new here, so I'd like to thank anyone for their advice given.
I am having a problem trying to design a circuit to switch between connections to my piezoelectric device. Basically I can use it as an actuator and a sensor. Electrically I think a piezoelectric can be thought of as a small capacitor, with one electrode grounded and the other connected to the circuit.
At one point I want to actuate my device my applying 200V to it, at another point I want to be able measure voltages generated by my device (of the order of 500mV).
I am measuring my low voltages with data acquistion board which can only handle +/-10V inputs so obviously I cannot have that connected when I am actuating my device with 200V.
Does anyone have any suggestions/recommendations?
Solid state would be preferable, with switching frequencies ranging from 1Hz-1kHz, current should be low, <200mA but I've designed everything to handle 1A. I have tried using some fast switching relays which are digitally controlled, but they don't work, still looking into why.
RE: Switching between 200V and Low Voltage Sensor
