Viscosity as a quality parameter?
This is an aside from the "Jet Fuel Bulk Storage" thread and responds to a question by FredGarvin. I have no doubt that there are specific issues here which might be more relevant to the "Engine and Fuel Engineering" forum but since the original query arises in this forum, it is where I will place it.
Fred asked:
"I noticed back in JMW's post in the referenced thread about Bunker C, his concerns regarding viscocity as a reliable measure of quality with heavy oil fuels.
Does this hold true for other fuel types? We base our daily inspections on specific gravity. My thought is that if it is a good indicator, perhaps we should be testing for viscocity as well."
I can only comment on the importance of viscosity in heavy fuels and to observe that viscosity (and density) vary for refied fuels. I do not know how significant these variations will be on performance. Hopefully others can inform.
Viscosity is a valuable process measurement in many areas because it is a very sensitive indicator of change, more so than many other process measured properties, but only where the viscosity is significant i.e. due to the resolving powers of the measurement instruments.
But there are other factors to consider as well.
Viscosity is a valuable measurement with heavy fuel oils because they are blended based on the volume or mass ratio necessary to achieve a specific fuel viscosity. Fuel blend calculators are used to preduct various quality parameters at this blend ratio.
The viscosity is the most sensitive of the indicators such that, within the instrument resolution, if the viscosity is right then the other parameters will be within spec also. If we measure the density instead, then, within the resolution of the density measurement, it is possible that the viscosity and other parameters may be out of specification.
A point with heavy fuels is that the viscosity of the blend can be 180cSt, 380cSt or 500cSt.
Diesels, aviation fuels and other refined fuels are blended for other properties.
Niether density nor viscosity is a controlled parameter. These properties can vary according to the refining history.
Two sequential batches of aviation fuel/diesel/petrol of the grade and from the same refinery can have very different densities and viscosities but still be in spec.
To produce fuels which do have controlled density and viscosity properties, in addittion to their other properties, will add cost. I am not in a position to comment on the benefit. When racing formula 1 cars the lower the density the better if, per litre of fuel, the performance of the fuel is unimpared. Consistent viscosity might also give consistent mixing and combustion properties.
But is it signficant? i.e. is the cost benefit ratio acceptable?
Viscosity is certainly an important factor in injector design, or rather, manufacture, to be able to know or correct for viscosity when testing injectors.
At low viscosities e.g. 1-4cSt, the current viscosity technologies lose their advantage of resolution compared to density, for example, in indicating other properties if they are linked. Density can be measured to within +/-0.1 to 0.15kg/m3 while at 4cSt, viscosity to +/-0.1cSt no longer has the same resolving power for a process measurement.
None the less, both density and viscosity, even though uncontrolled variables, are valuable process measurements in interface detection. For example, when transferring petrol (gasolene) from production to storage, the differences between the densities of different batches enables the detection of the interface between grades for proper diverting of the products to the correct storage and the control of ullage. Viscosity is far less useful for these applications though for improved confidence in product identity of diesels and aviation fuels measuring both the density and the viscosity together provide a much better confirmation that the product measured is the product expected as these fuels usually do exhibit good resolvable viscosity variation. Petrol, probably not. That is, the viscosity can be measured reasonably well but not well enough to discriminate between batches.
If the original values of density and viscosity are recorded either or both may be useful in detecting quality changes or for identifying if the product is not what is expected.
Viscosity, though uncontrolled for refined fuels, does have an effect on spray patterns and/or flow rates, hence the references cited to power factor correction in the original thread.
In the case of any engines where there are uncontrolled fuel properties, the design and performance specifications reflect the tolerance of the engine for the range of expected conditions.
In Heavy fuel engines the variation in viscosity is significant and is controlled because of the performance benefits.
Turbines for marine applications normally burn MGO or equivalent. There is no control of the viscosity. However, if the turbine burns IF30 (30Cst fuel) then the benefits can be significant but the viscosity variation with quality and temperature are also significant and must be controlled.
The fuel cost differential more than balances the added equipment cost. For a high speed ferry operating in South Amrerica somewhere (don't recall where) the fuel cost savings were estimated at US$5000 per day burning IF30 compared to MGO.
Work to burn heavy fuel oils in turbines is in progress.
So viscosity measurement and control that enables cheaper fuels to be burnt is cost effective.
For a refined fuel, the difference between viscosity measurement and control and no control is more difficult to assess. I am not qualified to comment. This is where i suggest the question might be more appropriately addressed in the "Engine and Fuels Engineering" forum.
I don't know who may have done studies on this or who may have any data. Until now most viscometers were insufficiently accurate to make such investigations worth while. Viscometers are evolving at a significant rate but it is not just accurate and affordable measurement, it is what is doen with the measurement that adds cost.
Fred asked:
JMW
www.viscoanalyser.com
Eng-Tips: Pro bono publico, by engineers, for engineers.
RE: Viscosity as a quality parameter?
Excellent point JMW. Yet another item I will be examining in the very near future. During teardown procedures, I can not verify if any type of flow pattern checks were performed. It also opens up the possibility other periodic checks.
Excellent post. Thank you for taking the time to author it.
Speaking of diesel-based fuels, their viscosity is important primarily because of its effect on the injector system and the handling of the fuel by the pump.
Viscosities can affect the fuel spray as jmw has indicated.
Short excerpts from the ASTM Manual of Significance of Tests for Petroleum Products follow:
Too high viscosities can be the cause of poor atomization, large droplets, and high-spray jet penetration, difficulting the mixing with combustion air. The combustion may be poor and accompanied by loss of power and economy. If the engine is small the the spray may impinge upon the cylinder walls washing away the lube oil film, and causing dilution of the crankcase oil. A fact that contributes to mechanical wear.
On the other hand too low-fuel viscosities result in a "soft" spray that doesn't penetrate far enough in the combustion chamber for good mixing, resulting, as above, in impaired combustion and decreased power output and economy. Excessive leakage past the plunger in the injection pump can be a result of too low a viscosity, with inaccurate fuel metering and reduced engine efficiency. Again wear of the fuel system components nay increase because luricating properties of fuels tend to decrease with viscosity.
The very viscous fuels used in large stationary and marine engines may require preheating for proper pumping, injection, and atomization.
Even free-flowing fuels may become thicker, and eventually solid, as temperature decreases. Because fuel handling systems rely on the efficient lubrication of pumps and flow dividers by the fuel, very low fuel viscosities are sometimes unsuitable. Boundary lubricant additives may then be used or, alternatively, the use of fuel systems not needing much lubrication may suffice.
Even aviation turbine fuel specifications (ATKs) require tests of "fluidity" including freezing point and kinematic viscosity (mm2/s) at -20C measured by ASTM D 445.
My problem is that while I know that these are concerns for large diesels, exactly as you say, what I don't know is how significant the problems are for gasolene burning SI or diesel burning CI engines where the viscosity will probably be not more than a few cSt cold and where the fuels usually receive some heating from the engine manifold reducing the viscosity.
Is there a reference number for the ASTM Manual you mention and what are its terms of reference?
For me, the question is will viscosity measurement and control have any advantage or does the design of the fuel flow to achieve manifold heating and combustion chamber design overcome these problems for small engines or is there still some potential advantage?
JMW
Thank you for that ASTM reference. I will definitely be looking into that.
If I understand correctly the fuel lines do pass over the engine so that the fuel is heated and provides some local coooling of the engine (correct me if I am wrong). For cold starts an electric fuel heater could be used.
Anyway, if the fuel is heated too high when running normally, a simple trick might be to split the flow so that some is heated and some not. Then recombine them in a static mixer with a temperature sensor on the outlet and use this to control the heating by controlling the fuel split.
Of coure, the temperature setting would depend on the known viscosity of the fuel and the optimu viscosity being known also. I haven't looked into if any of the modern viscometers would be suitable for jet engine applications, I don't see why not, there are so many of them now that specification shouldn't be a problem.
Sorry, I am thinking already of engine mounted. In a test bed more things are possible.
Actually, the Weston Aerospace fuel density meter is probably a good starting point for a fuel viscometer as it uses the same vibrating spool technology for fuel density, altimeter, air speed etc. i.e. it is already aviation spec. .... just thinking aloud....
JMW
Some good information on fuel spray patterns etc.
Some of the other factors discussed might also be relevant.
http://www.personal.psu.edu/faculty/c/x/cxm283/research/LF/Liquid_Fuels.html
JMW
