- Talk With Other Members
- Be Notified Of Responses
To Your Posts - Keyword Search
- One-Click Access To Your
Favorite Forums - Automated Signatures
On Your Posts - Best Of All, It's Free!
- Students Click Here
FOR ENGINEERING PROFESSIONALS Come Join Us!Are you an
Engineering professional? Join Eng-Tips Forums!
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting GuidelinesJobs |
Paint/coatings engineering Links
Click here to add a link to the Eng-Tips Link Library. Commercial VendorsAdvanced Industrial Coatings AIC is an industrial coating applications company. Website describes coatings applied, including PTFE and fluoropolymer blends, PPS, Epoxy, Polyurethane, etc. CAS-MI Innovation Center The CAS-MI Innovation Center helps entrepreneurs and established corporations create new paints, coatings, adhesives, sealants and other specialty formulated products. CHEMISENS-extending reaction calorimetry We offer advanced reaction calorimetry systems for process development and optimization, reactive chemicals and hazards assessment. Coastline Industrial Coatings Manufacturer of industrial paints, enamels, epoxy, primers, polyurethane, zincs, elastomeric roof coatings and solvents since 1972. All MIL-P and RAL colors as well as 2 & 3 coat systems. corrosion coating ECK(R)is a patented dissimilar metal corrosion coating. Comes in aerosol and liquid.Prevents stainless steel reaction when assembled with aluminum Element Analysis Corporation Advanced technology laboratory, providing testing services through spectroscopic methods, PIXE, PIGE and FNAA for non-destructive, rapid turnaround, elemental analysis of solids, powders, liquids, filters and wipe samples in a wide variety of matrices. Flexible Engineering Solutions Flexible Engineering Solutions is an independent provider of training and consulting services. We specialize in the creation and support of mechanical and thermal computer simulation tools and customized engineering training. HVLP Spray Guns and Air Spray Gun Professional Gra An online e-commerce for Professional Grade HVLP spray guns and air spray guns and related equipment. Free shipping on all spray gun purchases. Free consultation for all spray equipment applications. Magnolia Plastics, Inc. Established in 1957, Magnolia Plastics provides professional epoxy solutions to the Aerospace, Automotive, Defense, Construction, Airline, Bridge, and Recreation industries. Masking and hanging solution Masking for paint and surface finishing industries. Materials Testing & Failure Analysis Consultants in in the fields of engineering, failure analysis and materials testing. Specializing in corrosion control and corrosion research. Metal Coatings Corp. Metal Coatings Corp. is an applicator of industrial coatings and equipped for responsiveness in the application of protective, non-stick, lubricant, chemical resistant and anti-corrosion coatings. MinTech International, Inc. MinTech International, develops and markets a complete line of attapulgite gel products, and dry and wet ground mica. Product Data sheets are available at our website. Online Maintenance Management A World First - Complete Online Preventative Maintenance System - A Maintenance Management Solution - 90 day Free trial Painter's Nation, LLC - Industrial Coatings Manufacturers representative of industrial coatings, paints, and sealants for distributon and direct sale to the petro-chemical, oilfield, fleet, equipment and tanking industries as well as independent contractors. Progress Paint Offering residential, industrial, and commercial paint for interior and exterior applications. Stains and varnishes, spray paints, primers, and marine paint also available. Pumps of all types, just a click away PumpBiz is a large national distributor of all types of pumps in all materials. Easy access to information, selection and ordering is made available at www.pumpbiz.com or call 1-800-PumpBiz. Roof Coatings Roof Coatings and Elastomeric roof coatings for roof repair in rv roof. Elastomeric Roof Coatings can Fix Roof Leaks in Flat Roofs, RV Roofs, Asphalt Built Up, Modified Bitumen, Metal Roofing, Polyurethane Foam and Single Ply Roofing (EPDM, PVC, TPO). Rustbusters Ltd Rustbuster Ltd. offer methods for rust proofing, rust converting and treating rust to save certain items which are at risk to rust like cars. Shut off solutions for coating processes So called Pinch Valves as the ideal shut of or dosing solutions for different coating processes instaed of convential ball-, plug or gate valves. Solar Energy Corporation Low emissivity, high temperature radiant barrier coatings, for energy conservation, building, construction and manufacturing. Selective coatings for solar absorbers. Teflon Coating Stainless Steel Precision Coating Co., Inc. is one of the largest plastics coating applicators in the world, specializing in PTFE and Teflon« coating applications. The Hendrix Group, Inc. The Hendrix Group Inc. is a corrosion, failure analysis and materials engineering organization in Houston, TX. Our website includes newsletters, corrosion photographs, discussion forums, case histories and material data. Valpac, Inc. - Adhesives for Industrial Use Valpac, Inc. manufactures industrial coatings and adhesives. Products include laminating, pressure sensitive, heat seal and cold seal adhesives. VALPAC also custom formulates and toll manufactures both water and solvent based products. Viadon LLC Custom converter of industrial tapes & molded products. Full line of high & low temp masking materials. In-house rotary & overhead die-cutting, tape slitting, with custom molded part production & design assistance available. Most items ship same day. WHAT A JOB-Industrial Eco Friendly High Impact Coating.Applied on metal,wood,concrete,asphalt,fiber glass, rubber & PVC surfaces.Forms a Rock-Hard inti-slip/smooth finish.Flexible.Resistant to salt,moisture,rust/corrosion,chemicals,acids,gasoline,oil.Colors General InformationCorrosionsource.com Vertical Portal site for corrosion and materials industry. Comprehensive information on corrosion, cracking, oil and gas, failure analysis and more. Pipe marking and labeling solutions Information on proper marking of pipes, including ammonia piping. Free pipe marking guides are available as well as information on equipment used to create pipe markers, signs and labels. The Materials Market Research File The Materials Market Research File provides in depth coverage of market research in the field of coatings, listing content related and competing reports together so that clients can easily compare the products of different publishers. Promoting, selling, recruiting and student posting
LINK TO THIS FORUM!(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Paint/coatings engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=332
DESCRIPTION: Paint/coatings engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden. |
